I just bought a 1995 seadoo xp with 717 engine. The first outing on it, it ran fine first 30 minutes or so. Then it started bogging down, then run fine for minute, then bogg down. I accidently pulled the lanyard and killed the motor. After that I couldn't get it to crank. The motor turned over but won't start. When I got it home i discovered the attached pics. The tubing was attached where i have it circled in red. I noticed this before I took it out but it was in tact at the time but when I inspected it after my troubled outing i noticed it in the condition in the pics. Why did they have this tied off and could this be my problem?
I did a compression test. Both cylinders registered 120 psi. I replaced the line and tied it off like they had it but can't remeber if i did the compression test before or after i replaced it. Would that have messed with the compression reading if that wasn't tied off. I just thought it was strange that both cylinders registered the exact same. I am totally new to this so please be patient
