What is the proper break in procedure for a 951 DI?
russellb
I just had a remanufactured engine put in my 2002 GTX DI. The mechanic said that I should add about 10 ounces of 2-stroke oil to the first tank in addition to the oil tank. Then I should run it for about 20 minutes and then let it cool and repeat for a few cycles. Any break in advice from those experienced on the DI engines would be greatly appreciated. I want this engine to last. I have more money in it than the ski is worth.
Your mechanic scares me a bit.... ;)
No need to add oil to the gas. It won't do anything except put your fuel injection system at risk.
The DI engine injects fuel into the combustion chamber so added oil will never do anything but make more smoke come out the exhaust. The idea behind added oil to the fuel is to help lubricate the cylinder walls. In a conventional engine that mixture passes through the whole engine before being consumed. On the DI, it never enters the crankcase. The extra oil is supposed to be added to the crankcase during engine assembly to help lubrication.
There's no real trick to breaking them in. In the manual, they just tell you to vary the throttle & keep wide open bursts to a minimum at first, BUT, that those wide open bursts will help a good break in.
So long story short. run it normal, but don't hold the throttle in the same position while cruising. a WOT throttle pull is good from time to time, but keep it under 10 seconds each time & wait at least 20-30 minutes or so of cruising before running past 3/4 to Wide open pulls. But keep all the cruising under 3/4 throttle otherwise.
If something seems funny, running rough, stalling, etc. Shut it down & look into it. even a fresh DI engine should run perfect the very first time its started up.
One other thing I like to do on a fresh engine is run it for about 5 or so minutes, then shut it down & let it cool off. Run it for another 10 or so minutes & shut it off again & let it cool. The idea is to let the cylinder walls & rings cool down as they are getting much hotter than normal as the rings seat. However those cylinders are cooled so well from lake water, it might not really be a necessary step.
the manual doesn't say anything about this on a DI. but it can't hurt.
I was thinking of riding it easy and using the learner's key through the first tank of gas. It was started for a few seconds on the trailer. Maybe it would help to spray a little fogging oil into the cylinders before start up?
Thanks for the advice. I'm not going to add the oil to the gas. What kind of oil would you run in it though? The tank is probably about half full. I haven't bought any more oil yet.
I have always run the oem XPS synthetic oil. It's the "great debate" on brands, but as long as you run a good quality synthetic that is compatible, you should be fine. just do a search on oil & you'll find too much info, I mean info... :D
I normally drain the oil tanks on skis, if I don't know what is in there currently. On skis That I was told by the previous owner what was in there, I still drain the tank. ;)
Unless I saw the PO pour it in the tank, its a crapshoot & not worth the question marks in my head......
68RT
Today I drained the tank because I wasn't sure what the dealer put in there. He sells Amsoil so I'm sure it was an Amsoil product. I went to the SeaDoo dealer and bought the proper synthetic in. Should be good to go for quite a while with a full gallon in the tank. Will try to finally get the ski in the water tomorrow to check things out.
