cholber1
1995 spi i replaced the wear ring rebuilt pump whole nine yards impellar looks good so i reused it. Anyways after the new wear ring went in the impellar was hard as hell to get back in. I have to use dish soap and coat the wear ring to get it in now after its all back together when i try to fire it it will barley crank over the shaft moves maybe an inch at a time cause its so tight am I doing something wrong or is there a trick to lube that thing down to get it to crank over to start and wear the ring in? Any help would be great. Thanks
