raptorrider660
I have the new wear ring and fixing to install but the original one had (4) small screws holding it in. Do I need to use the screws on the new one that I install ?? Also on the orginal one there is some black plastic that is also chewed up that is located on the backside (in the middle) of the old wear ring. Do I just cut that out as well ?
Also do I need to let the "red loctite" cure for a set number of hours ? I wanted to go try it out today!!
Thanks
Thanks
