I installed a new Seadoo Wear ring on my 1996 GTX. The impeller spun easily and I had good clearance all around. I recently installed the engine so it is lined up very well. AFter installing the Jet pump I had trouble turning the new engine by hand with the spark plugs in. Usually I can get it to move. I pulled the spark plugs and still could not turn the engine. I put the key in and th engine turned over nicely. I crawled under the ski only to see a rub on the wear ring and some plastic.... very small amount on the impeller. I put the plugs back in and started the the engine and ran for 10 seconds. Shut it down and I could turn the shaft by hand. So it was just a rub but I now I wonder.
What is deforming the wear ring ? I checked the jet pump landings and they are all flush so the pump should be square on the mounting face. I am considering removing the pump and having a look. I just don't like it. Thoughts??
