Weak stream at idle?
LSaupe
How strong of a water stream should I have out the vent (pee tube) at idle?
Currently at idle I have but a dribble but it does get much stronger under higher power settings. I was thinking it was better at idle, but can't recall.
Is this common? What should I see at idle in this regard? Idle RPM set at 1600 RPM in the water.
Larry S.
Wow, just found something that is sure to be a player. My inet and oulet houses (to the head) are reversed.
Besides the difference in intermediate pressure drop at the vent, I am sure not the intended temperature profile through this engine/pipe.
Depends on the idle speed, impeller, and pump condition.
It can be anywhere from a small stream, to a good squirt. The biggest thing is that it is spraying out when you rev it up.
One thing to watch for, is change. If you normally have a "Good squirt" at idle... and one day you find that it's just a trickle for no reason... make sure you do a good flush to push out any junk that may have gotten into your cooling system.
This is very important in places with a lot of grass, or weeds.
