Taylor4616
My main question is what about the oil in the crank case?? Does it have to be drained or can it even be or is it ok or is there water mixed in the oil like a car? I assume i can’t check it like a car dipstick...Ok so i have a 2000 Rxdi and i un loaded my seadoo off the trailer and when to get on it when i realized that I was taking on way too much water after I got on it before I even tried to start it so I jumped off of it Realizing I forgot to put the drain plugs back in and pushed it back to the loading dock .I put it back on the trailer and I waited for it all the water to drain out which it was almost completely full to the top of the motor...so i took it back home and started watching YouTube videos and I removed the spark pugs and started turning over to blow all the water out ,then removed the air cover assuming that's were it got in from....and it now starts up and runs on land...but my question is what about the oil inside like under the cylinders in the crank? Im very new to pwc a i have only got to ride it 2 an 1/2 times before this happend ,so im not exactly sure if theres any thing else im supposed to do or if its lake ready again...any info very much Appreciated
