Water in Cylinder #2 and in oil
YellowMachine09rxt
Just wanted to share a problem I ran into the other day, picked up a 2009 Seadoo rxt 255 is for a very cheap deal couldn't pass it up was not currently running when I originally got it solve the problem of starting issue by rebuilding the Frozen bearing on the supercharger oil look good decided to Crank It Up started good and driveway then took it to the lake only maxed out at 5200 RPMs wot took the ski home checked everything discovered water in the number 2 cylinder and in the oil, found water was being shot in from the intercooler that cools the supercharger replaced the supercharger intercooler problem fixed! just wanted to share if anyone had this issue thank you guys
Common failure, good you were able to figure it out on your own. Important to winterize properly as water in the intercooler when frozen will damage it. Change the oil and the plugs and you should be good
