It depends on what is going on... You should replace all of the "grey tempo" fuel lines. They are grey in color, and have the words "grey tempo" written on them. The fuel lines were never designed for ethanol fuel, and the chemical reaction creates a green goo. This goo clogs your fuel selector, and the filters inside the carburetor. IF you have the lines, the carburetor needs to be cleaned to prevent a lean condition, and engine damage. Standard black fuel line will work. Make sure to use 100% stainless hose clamps.
IF you clean the carburetors, use OEM Mikuni kits. DO NOT use cheep ones. They do not work.
When you use the garden hose, do not turn the water on before you start the ski. Follow: Start ski -> Water on... Water off -> Stop Ski. IF you turn the water on before you start the ski, or after you stop the ski, you have a VERY good chance to hydrolock you ski.
Why do you need to adjust the oil pump cable?? At idle, there are two marks that need to line up.
