superheropunk
From my research it is most likely these 2 things:
1. Impeller/Wear Ring
2. One of the cylinders is not firing
I read about a quick test where you pull the black spark plug cap on each spark plug one at a time and see if it runs rough or will not run. Trying this the jet ski sounded fine with the 3rd spark plug cap off but wouldn't start with the 1st nor the 2nd (one off at a time) black spark plug cap removed. Hoping I did it wrong or that is not a valid test. The engine looks so like new so really think this is not the issue.
Ordered the impeller/wear ring and am hoping this takes care of the problem (did get the ski rope wrapped around the shaft but am very confident all the rope was removed successfully). I am somewhat mechanically inclined but if it is one of the cylinders not firing may have to take it in as I don't have some of the tools needed to diagnose it properly.
