Ski set up for a couple of years,now when i run it the hi temp light comes on i checked all cooling lines,with the hosepipe hooked up seems to be fine. Drained gas and oil to make sure that is not the problem,but when i give it time to warm up no hi temp light. Only when i hit the gas then the high temp light comes on. It was fine when i parked it. Also there is no leaks like a craked engine and the tops of the pistons do not seem to be overly hott could it be a bad sensor? ?? Any help is greatly appreciated along with a parts supplier because there is no sea doo parts at the country store. Thanks ..... It is a 1999 gtx limited
