2018 300 GTX - Battery Alarm
24CK
Looking for some advice
Have a 300 GTX Limited and sometimes after use, when I press the off button, I get the battery light and alarm.
No symptoms though - starts fine.
In the last 2 months it’s had a new battery, regulator and starter relay.
Is it nornal to get the low voltage alarm after an hour or so of use?
Not normal, battery should be at peak voltage. Next time it happens check your battery voltage. If the warnings are correct you are running the ski off the battery instead of the magneto. Grab a service manual off of eBay there is a whole section dedicated to the charging system.
