VTS issue on 1996 XP
VTS motor bench tests perfectly in forward and reverse on battery with test wires. When the VTS module is hooked up to the craft and motor (all wiring), the relay activates inside the VTS module when up or down is pushed, however, the motor still does not activate. At times when I am performing this test, the 7.5 amp fuse in the relay box (rear box) blows.
Any suggestions? than you in advance!
