If you test the gauge and its good, more likely than not the box houseing is bad, and
you can replace that, then all should work.
When the box module goes bad the glass reed switches will not send the position to the gauge.
Sometimes, when it does, THETRIMFIX.com is a recommended cheap fix solution. Bills86e
