T tvallejo New Member May 9, 2011 #1 BATT Voltage remains unchanged with one or two engines running. (12.3) Static Batt voltage. Rumor has it that if one Regulator/rectifier goes bad on one engine the other engine will not charge as well. Is there any truth to this?
parrothd Active Member May 9, 2011 #2 Maybe one was bad, then you burned the other one up... Buy a replacement one and see what happens, you can't test them other than what you've done.
