Hooking up the trailer lights on my 2000 Chevy 2500. I sort of rigged up the wiring, and now the brake lights are lite when the tail lights are on. And I know why, I have both the brake wire and running lights going to the brown. This was the only way I could think to hook it up. It had a 7 pin, but the PO had the wires all jacked up so I just linked into the wires for the tail lights. So basically I need to make it so when the running lights are on it doesn't go back into the brake lights.
It is brighter when you hit the brakes, but not much. Everything on the trailer seems to work fine. Is there a way to make it so it doesn't back feed. Below is a crude picture of how its hooked up, ignore the flat lines, that was just to get my spacing. Thanks for anyhelp you can give.
___________________ / tail lights
__Truck tail light feed--\
_____________________Brown trailer light wire
Truck brake light feed--/
____________________\brake lights
