On that motor? Absolutely.... the 951 motors are tricky to do in the ski, but entirely possible with rubber band trick. On yours, just be sure to align the jugs properly but putting the exhaust manifold on fairly snug (not all the way tight) after dropping the cylinders on top of the cases. Don't tighten the bolts into the cases to secure the jugs until the exhaust manifold has been snugged up and everything aligned. I recommend using some loctite 518 anaerobic to seal things up as well. Not loctite red permanent. .. use 518.
