99 Seadoo GTX Limited
Ski was running fine, no issues. Had the starter go out, couldn’t get it stabbed without removing the carbs so I did and got the new starter installed.
Took it to the lake and noticed it was hard to start but started. Then when when on the lake I tried to give it full throttle and it was having issues like starving for fuel and wouldn’t run full throttle, actually hard to get going.. Took the carbs off made sure everything was tight and looked right. I did find a small fuel leak on number 2 carb (rear) on the pumper. Replaced that and now it’s starts like it should.
While running it with the hose hooked up, i had a call so stopped the engine and tried to start it 4-5 minutes later, water was still on. When I tried to start it, it was water locked. Removed the plugs and did what you do in these cases.
Took it to the lake to see. Runs better but seems to be starving on the top end. Runs good for a few then bog down then back up again.
To those with more experience with seadoo, is this a head gasket issue? I rebuilt the carbs at the end of the summer last year due to a pumper was going bad. The kits were from the dealer and wasn’t an off brand, true oem.
Thoughts?
Thoughts?
