flow... pm sent re: radio shack
but was rejected, your inbox is full due to the ridiculousness of this forum having a 30 pm limit...
re: riding,,, just gradually work up speed and hit the corners hard, assuming your running stock sponsons you can work your way from 180's to 360's by learning how and when to throttle out of the spin, and weight adjustment. Just hold on and go ! You can turn on a dime, don't sweat it.
Rule #1 remember to let go if your getting tossed, better to toss the captain than flip the ski.
there is a gas gauge fix sticky up there if I remember, it will likely solve your issue there.
the speedo ? (well this is just me) screw the speedo, its not that accurate anyway. but if your anal about stuff the problem is likely in the wheel not spinning freely or missing blades or sticking, you can look into replacing the unit, but IMO its a waste of time/trouble, a handlebar mounted etrex gps will give you speed thats more accurate and track your total miles as well, assuming that its important to you.
I gave up on the speedo maily cuz the first hull modification I did was toss the 3 gauge hood in the dumpster and put in a single gauge hood with info center only, so that solved my speedo problem... my tach was replaced with a TTO so the RPM problem was solved as well
My Tach tells me how fast i'm going,, i idle at 5mph, 4500ish is 35mph, and 7K is 60mph... easy peasy lemon squeezy.
