The first steps to engine instalation
Jonnyivy
Hi,.. here goes with my first of many questions,...
I have a seadoo 951 injection, almost built back up and now after reading several posts and manuals I feel I'm ready to get the engine up onto the pulley and lower it into the hull.
What are the initial steps that need to be done before I can think about connecting the mounting bolts ??
I imagine I will need to link up the crank case bottom water pipes as these will not be reachable once the engine is sitting on the mounts ?
What about the prop-shaft ? Can this be linked up later ?
The reason for the in-experience is that I bought the ski with the engine already out so I don't know where everything goes (but I'll learn )
Thanks for your help,
Jonny
do you have a alignment tool or a way to align the moror? on mine i just lowered it in there slowly and hooked up what i had to and then made everything loose and did the alignment then bolted it down and put the thing back together.
