despower
Looks like I posted this in the PWC forum by accident.
My sportster is giving me a Fault Code 5. According to my Shop manual, this points me to one of four possible sensor problems. I don't have the Vehicle Comms kit (bummer) so instead I went through all possible problems associated with code 5... these could be water (WTS), exhaust gas (EGTS), manifold actual pressure (MAPS) and throttle position sensors (TPS).
I checked resistance on WTS (within range) and the EGTS (within range) from the amps connector. I also checked the MAPS, and this seems OK (no dirt or obstruction, but I don't really know what the input impedances should be because the shop manual doesn't list them). Next I checked resistance on TPS (both the MAG and PTO side potentiometers). These all check out to within specifications.
And now for the problem...
On the TPS testing, the shop manual suggests to check the voltage coming from the Multi-purpose electronic module (MPEM) to the TPS potentiometers. The three TPS PTO side signals check out according to specs (5V, 0V and 0V), but the TPS MAG side signals should be (5V, 0V and 4-5-5V) and instead I am reading (3V, 0V and 0V). Since these signals originate from the MPEM, does this indicate that the MPEM is defective? If so, that would suck, big time. Replacing sensors are no big deal, but I suspect that the MPEM replacement is a big job that would have to be done in a shop with all proper equipment.
Advice would be most welcome at this point.
Des
Des
