My iron is probably not the best but seemed to melt the solder on all the contact points. Not sure what the ic chip is.. The black one? Didn't touch that one. I did reseat the logic board several times though. The board doesn't look burnt but definately need a magnifying glass which I will have to get. The gauge needle moves freely so the motor isn't frozen. The problem is I bought the boat with a smoked mpem which I replaced but the boat sat under a tree for 4 years. Thinking the tree took a lightning strike and boat got a static charge from it???
None of the gauges work at all but they do light up. I do have a multiple meter but have no idea where to even look at on the board. Your help is greatly appreciated.
Let's check out the actual guage coil now.
Gently pull off the guage indicator needle
on the face of the gauge. Then gently remove the
plastic face with the numbers on it.
Once removed you will see a clear plastic
mount with 2 small black flat head screws. Remove those.
Now remove the logic board from the back so we don't damage any
components.
You should now have the gauge coil on it's own in your hand.
To test it you will a 9 volt battery and 4 small testing cables.
You can use just about any cables to test, even speaker cable.
Inspect the front of the coil in the front and confirm all the coil
wires are connected to the 4 terminals in front.
If everything looks good let's proceed with the test.
Hold the gauge so that there is a terminal on top, left, and right.
There should be none on the bottom.
The 2 on the left and right should connect to the 2 + and - battery poles.
This is the constant power.
The next connection should be made to the metal shell of the gauge.
Hold the wire to the metal shell of the coil and connect the wire to the - of the battery.
So now you have 3 wires connected.
The constant power and the negative for the gauge movement.
The last wire connects to the top terminal on the gauge and because the
signal that comes from the engine is not constant you have to pulse the voltage. In other words tap that last cable to the + batery pole 4 - 6 times per second.
You actually may want to attach the gauge indicator needle again so you can see it rise.
You also may need 2 people to do this, or 4 hands.
The gauge if working should rise up to 2-3 rpm is pulsed correctly.
If your up to it, give this a try.
Hopefully it doesn't sound to complicated.
Let mr know if it works.
