67Charger
I picked this ski up a while ago as a "trailer for sale with free SeaDoo" type of deal. I picked up better ones ( '97 SPX and '97 GTS) after it, so this one needs to go. It actually runs good, barring the residual issues from the Tempo lines that were still installed. Carb kits will cure those ills. New fuel lines are already installed. The issue that I'm struggling with the head bolts. 2 are loose (not touching the head) but seized in place, and 1 is broken off 1/2" down. The head still seals, compression is good, but water leaks from at least one of the bolts. The broken and fully seized bolts are on the Mag cylinder and separated by a bolt. The one that moves a bit is on the PTO side.
Using PB-Blaster, I have one bolt able to work back and forth about 1/2 turn total. Any magic tricks? I know it is corrosion I am fighting, so what seems to work best here?
If I commit to pulling all the bolts out by whatever means necessary, I fear I'll break quite a few and screw the jugs. As-is, the bailers can keep up with the leak no problem. Probably 2-3 oz./minute.
Thanks!
Thanks!
