Strong Gas Smell from RXP
MGRXP94
I have an 06 RXP and have a strong gas odor in my front storage compartment (where the gas tank is), but even when it is closed up under a cover in the garage it still makes the garage smell like gas. What do I need to check, any places in paticular? If anyone has any pictures of where I should check that would help too, I'm not really an expert with these things. Thanks
Considering that gasoline vapors are highly flammable and inside an enclosed hull they can even be *explosive*, and you aren't an expert, you might aught to take it to an expert and have it checked out! And if your garage is smelling like gasoline, keep in mind it's explosive you could burn down your entire home if something ignites the fumes!
In this case, I'd suggest hauling this watercraft to a dealership or PWC repair shop and let them check it out. It's not safe like this. It sure isn't worth burning your house down to save a few bucks!
- Michael
