The beginning...
got ski 3 years ago, it has never run right.
At first it started great but wuld never go over 10- 12 mph
have rebuilt carb, changed out fuel lines, changed oil, fuel, sparks
went trough a couple gyrations where it was really hard to even start (change springs in carb to differnte rating to fix. still doesn't start as easy as it originally did but does ok
So now am here.
Basically I'm running just one and a half to two turns out on the low valves. When more I was pretty sure it was flooding but yeah I've had them all over the place. Have tried, and am currently running hotter plusgs (6 insted of 7) tried running w/o spark arrrestor in case it was causing issues. Results consistant as follows:
Starts up and goes like a rocket at will. I start getting tired of holding on and slow a bit ...down to 25 ish, then drop down even further. Hit it to go again and it gets to about 10-15 mh and just stutters. (sounds alot like original problem eh? - only at first it would never take off)
so I go to shore adjust low end valves some, half turn up/down whatever tinker a bit. maybe 5 to 10 minutes max. Start it back up and think I've solved it because it takes off again. Well same thing happens, it is good for a bit and then won't go over about 12 mph again. Take to shore, tinker, repeat.
Then eventually swim the stupid thing or look for a tow because the battery is exhuasted.
Thoughts?
So now am here.
Thoughts?
