Still get air bubbles in oil line !!!!!!!
mario medeiros
Replaced all the lines on my 94 GTX and ran it 2x with mixed fuel and now 2x with straight gas and I keep getting small bubbles in the line going to the pump after the filter .
Thing runs great and is using oil from the tank as I can see it going down should I be concerned or ???
Thanks
Yoy did try removing the bleed screw correct?
Hold the filter vertical and flick it with your finger to help the air out.
If there is still a bubble you might have to disconnect the hose from the filter quickly to "burp" the air up and out.
Oh never thought of holding the filter vertical good idea will try. You would think after 4 tanks of fuel it would have had all the bubbles out by now.
Thanks
