Steering Issues
JoshWyoming
Hello all, have a problem with my 05 Seadoo GTX. At 15mph and lower, steering works. Above 15mph I have NO steering. Any ideas? Everything looks normal.
The cable is damaged. There's an outer sleeve that supports the cable as it exits the hull. It's probably come out of the cable jacket.
FYI... you will get more help if you post in the PWC sections.
Have someone hold the nozzle tight at the back of the boat while you move the handlebars. You'll probably find they move a lot when they should only wiggle a 1/2" or less. From there try to figure out where the excess slack is.. Most common is mentioned above but you could have also lost a hinge bolt on the nozzle or something at the bottom of the bars came off.
