Starter problem help my
Aneudi rxp
Greetings to all I have a sea Doo RXP 2005 My problem is the next the starter gets stuck Estartiando all the time as the only stop is if you disconnect the battery, I did the following tests
1. Remove the fuse and the problem continues. 2. Remove the cable coming from the switch and the continuous problem that can be the solenoids was damaged or just the starter is not good thanks for the help I can provide
