SPX engine stuck
vetanco
Hi everyone,
Im new to Jetski and I need an advise. I just purchased a Seadoo SPX from a friend of mine, and tried to start it but it seems that the engine is stuck and it wont turn over, the starter just clicks. I know for sure that my fried paid over $1300 to rebuild the engine and the turbine 2 years ago. He used it 2 times only since then its been sitting for long time. I assume the cylinders are rusted a bit because I cant even turn the crankshaft by hand. I did remove the plugs and sprayed WD-40 but no luck, Does anyone know any secret or I would have to open the engine?
Any help is gratefully appreciated.
pour some ATF down the plug holes, and let sit for a day or 2. Then, put pipe wrench on pto, and turn.
thanks thats a great idea, I never thought of it,
I at first I used the start button and I think something fried, cause after the 1st time the start button was not functioning anymore, I had to jump the starter cable directly after few more attempts no luck.
are there a more fuses in the front electrical box.
