Pictures of install thus far
Below I provide instructions for what I have done so far to install the Uniden Depth Finder gauge. I have included photos and screen grabs from the shop manual to help out.
Photo A - shot of steering wheel and location of depth finder gauge. As you can see, there is a Uniden Gauge above the steering column. This was the gauge that I installed.
Photo B - shot of blank. This is the gauge blank that needs to be removed so that the new depth finder can be installed. How nice that they put in a blank 2 1/8 hole for the gauge. No cutting required. I tried to pry the blank off, not realizing that the blank was screwed in place. Luckily I had the shop manual to show me that the blank was screwed in place.
Photo-C - removing wheel. To remove the blank, you have to remove the steering wheel with a 3/4" socket and a bit of muscle. The shop manual suggests using a steering wheel removal tool so that you don't damage the wheel. That would be nice to have, but I didn't have it. I just pulled it off. My Sporter isn't that old so the wheel wasn't fused in place. Nonetheless, I had to use a bit of extra force to pull it off once the nut was taken off.
Photo D - from shop manual. Shows that you have to remove the 3/4" nut and wheel (11). Also, to get at the nuts from behind the blank, you have to remove the steering column cover (12). This can be removed by removing the 4 bolts from the back of the steering column cover (not shown here). You get at these by lifting the console up and removing the storage bucket.
Photo E - front inside the console. Here is a shot that shows the back of the steering column cover and 3 of the 4 nuts that have to be removed to remove the steering column cover. These are hard to get at. You can see that I ran the transducer wire and the power/ground through the gap between the steering column.
Photo F - This is the wiring diagram from the shop manual. I connected the red power wire of the depth finder to SP4 which is a junction for 4 purple wires coming from the other gauges (tach, speedo, etc). I connected the black common wire to SP3 which is a ground point near SP4. Both SP4 and SP3 are underneath the console behind the steering wheel.
Note that you could also connect to the Yellow-Orange wires at SP5 which is also +12V. However, Yellow-Orange circuit is "on" all the time except when the battery switch is set to off. The purple circuit only comes on when you insert your key and turn the motor on.
Photo G - This is the photo of SP4 and SP3 where I made the connections for my power and ground. Note that here, the wrong cap has been placed on SP4 so it looks like it is SP1. I was confused by this for a while since I was referring to the wiring diagram, but this cap must have been wrongly put here by a service tech. I routed the transducer cable along the inside of the hull where a few other wiring harnesses are routed to the engine compartment.
Looks like I can only upload 5 photos with this post, so the next post will be the rest of the photos.
In a few days I will post the photos of where I installed the transducer.
Thanks to Karl's previous posts for help on doing this. I don't know if any of this adds any value for others trying to do this, but i figure I had a lot of help with the shop manual and maybe not everyone has one of these.
