Yelloyello
I have a Speedster 96. The portside motor starts in a second and then runs fine. It also accelerates like a rocket. Then after a 10 minutes the motor goes back from 7000 to 3000 rpm. When I push the throttle, it dies. When I pull the chocke, it also dies. Then a hard start and then it runs good till 3000 RPM, when I want faster, it dies. This happens sometimes. Not every time.
The cooling system is in a good conditioning
I discovered a small hose (few millimeters) that was broke. From the charts I learned that this hose has something to do with the oil. I replaced it, the motor starts again in a second and seems to running fine.
Did someone else has this problems?
Any causes/solutions?
Second, minor problem. The starboardside motor has no water on the bleeding hose. Still it cools normal, should this be a problem? Any causes/solutions?
Thanks in advance!
A happy Seadoo user. (my second one
Thanks in advance!
