X xder98 New Member Jun 20, 2020 #1 Water comes from the rotary valve lines and into the injection oil tank. What do i have to replace to fix this issue?
AKnarrowback Well-Known Member Jun 21, 2020 #2 Check your oil tank fill cap o-ring seal and filler neck.
X xder98 New Member Jun 21, 2020 #3 AKnarrowback said: Check your oil tank fill cap o-ring seal and filler neck. Click to expand... So there should no way of water entering the thank through the rotary valve?
X xder98 New Member Jun 25, 2020 #5 AKnarrowback said: None. Click to expand... I made a small tank for the oil lines that go to the rotary valve. This confirmed water is coming through those lines and my original tank is great. Could there be a cooling line in the wrong spot or something?
