Dougsnash
Guys, I picked up a 'new to me' 1994 GTS last week which has been sitting since last season.  I have been going through the machine trying to get it running reliably.  While I think I have most of the gremlins out of the beast, I have a couple of questions I hope someone can shed some light on.
1. Where physically does the buzzer live? I have two empty plugs attached to the back of the 'dash' and I suspect one of them originally held the buzzer. I have tested the overtemp switch and there is no buzz so I suspect the buzzer was removed at some point.
2. How do I know which size needle and seat to order for the carb? The manual lists which jets to use in the SBN-38 carb for the GTS but does not list the needle and seat size. The retailer websites I have looked at generally list 4-5 different sizes when I search the 1994 GTS.
3. Is there an 'ignition switched' 12v source on the GTS? I plan on installing a OEM style tach and fuel gauge, and adding GPS/fish-finder on the machine and don't want to drain my battery when the machine is not in use. According to the wiring diagram in the manual, the gauges should be attached to the same circuit as the buzzer but it is not really clear whether that circuit is switched with ignition or not.
Some of the tasks I have dealt with are:
Replaced the grey fuel hoses with ethanol resistant automotive lines
Replaced the fuel sediment bowl screen and o-ring with new
Ordered a genuine Mikuni carb kit (cleaned up the carb with existing parts until kit arrives but don't plan on running beyond testing until rebuild is done)
Cleaned up the ground connections and some ugly wiring inside the grey electrical box (MPEM is from '92 and has relays instead of fuses). I had very intermittent spark until I cleaned up the coil ground.
Trimmed back 1/4" of the spark plug leads to get clean wire.
Installed new NGK BR7ES spark plugs gapped to .020 as per the manual.
Installed a new AGM battery
Wet sanded the upper gel coat and polished and waxed the machine.
Ordered a new seat cover
Fixed the return spring on the oil pump, pump was stuck at full flow
I am going to service the pump cone next. I have a Klotz service kit ready to go in.
Thanks to all of the experts who answer these forum questions, I have learned much reading other peoples questions and the many detailed answers.
Doug M
Doug M
