Went to start ski and had nothing. Found that the 5A fuse on MPEM was blown. upon replace and battery connect blows immediately, so started disconnecting wires to mpem to try to find cause before changing MPEM. Discovered that the wire to the solenoid is the cause for fuse pop, as remove from solenoid does not blow fuse.
With this said, before changing solenoid, should I suspect solenoid alone, or could something else downstream be the culpit?
Thanks for the help in advance
