solas pitch size?
dml2010
im looking to purchase a new impeller for my seadoo xp ltd 99 ,whats the difference between the pitch size there seems to be many....
Go to The web site for the impeller you are looking to buy, and see what they recommend.
There is probably only one impeller recommended for your ski.
The numbers represent the angle or pitch of the leading and trailing edges...for instance....a 14/19 is bigger or taller and requires more power to turn than say....a 14/17.
If you've done nothing to increase power...it's probably best to stick with a stock prop....or maybe one with a bit steeper trailing edge if you're running in cooler weather.
