brettk
I have a 1998 Seadoo GTX Limited here is a list of everything that I have done to it
1.) Rebuilt carbs
2.) Changed all the gas lines
3.) Cleaned the rave valves
4.) New coil
5.) Fixed exhaust leak at the exhaust ring and at the manifold.
6.) Pressure tested the tank
7.) Check the fuel valve
8.) Grounds are all clean
9.) Fuses are all good
10.) serviced the jet pump oil
11.) Wear ring and impeller are in perfect condition
12.) Water pick up is clear
Ski will run good for about 10 minutes on a cold start reaching top RPM and top speed of 60 MPH then begins to bog down only reaching top speed of 29MPH.
After ski is warm it has great hole shot for about 10 seconds and then will bog down.
The ski starts on first push and continues to idle good and runs good up to 29MPH
I think I see some water on my plugs. Could a blown head gasket be my problem?
1.) Rebuilt carbs
4.) New coil
