Went out riding this weekend and I was having a few problems with my 1997 Seadoo GS. It was ridden for a few hours and after a while it seemed to have a decent amount of water in it causing it to be unstable (only about 4 inches deep). I figured it was from doing tricks and having the water rush up the nose of the ski, but then I ran in a straight line for a while to let the automatic bilge do its thing (they do have them right? I was pretty sure but maybe mine isnt working), it didnt empty. Not a big deal because the other ski needed to be refueled so we trailered both, pulled the drain plugs on the GS and fueled both up. Once the GS was fully drained I put the drain plugs back in (AND YES THEY WERE FULLY IN, I CHECKED MULTIPLE TIMES -lol). We put both skis in the water and rode them over to the anchors. We then went on shore to eat. The GS sat for about an hour and when we went to use it, it was filled with water (to the top of the engine).
I was wondering if there is a common cause for this on seadoos. I heard that the rubber boot and bearings for the drive shaft (where the shaft comes into the hull) have a tendency to leak. I also anchored the skis by attaching the line to the rear of the ski, could this cause water to be forced in through the exhaust system and possibly exit somewhere inside the engine bay? I have done this all season but they never sat for more than a few minutes at a time
. Any other suggestions other than a hole in the hull? I think I will be installing an aftermarket bilge pump this winter, just for extra insurance.
Thanks for the help
P.S. The GS's seat also seems to pop lose when riding some times. The front unclips if I hit a wave to hard but all bolts seem tight. Any easy fixes for this problem, otherwise I will just extend the metal tongue on the front of the seat.
Thanks for the help
