ski dont run like it use to
brandon32689
so my ski dont run like it use to and it sounds kinda wierd to me it is the first ski in the video and ski 2 runs great side by side it take it all day. both stock machines, but ski 1 has new wear ring and all prop looks great and compression is great it just is weird to explain, here is a video
sounds almost like its bound or something is holding it back,
http://www.youtube.com/watch?v=XU-bLakUm30
Ya cleaned em up good. It sounds dif than my other like hard to explain other than maybe my good ski seems more loose and this one seems tight
Are the raves operating/opening around 4400 rpm? Some times the WR needs adjusted to get it in sync. A sand packed cylinder drain line can
interfer with performance as well.
Bills86e
I'm not sure how to tell when they open? My cooling system seems fine engine stays cool and got a good stream from pissed. I got a brand new water regulator and even tried the one from my other ski. Ski ran great b4 pickup went out. Well to get that front cover off I had to loosen all motor mounts so when I got it back on I pulled jet pump and realigned motor good. Then I put it all back together and new rubber bumpers and I put a,new anti rattle nose cone as well. W new fluid.
Okay so it would cause it to sound dif? How van I be sure? I also did a pressure test after filling w fluid and it held 10psi
