Bad day at the lake. The engine shut off by itself, the lanyard was still on. If i understand correctly, its due to lean running. It´s a 1996 GTX
It happened while i was towing a tube and also a spotter on the ski, total of 3. The ski didnt move so fast because it was just like it was freewheeling, speed maybe 25-30 km/hr but i could reach almost 7000 rpm and it was smoking a lot. This went on for about 2 minutes, similar situation has happened before and that was due to seaweed and debris getting caught in the drive train or impeller. I thought it would clear up by going reverse and forward again, but it didnt happen this time. And it died by itself.
The ski has worked fine before this happened, stock carb settings ( havent done the plug chop test though), rebuild engine from SBT, rebuild carbs, new raves and housings, new fuel lines, and everything new in the drive train
Clogged cooling line from seaweed? too lean settings on carbs?
Did a compression test, MAG side, 150 psi ; PTO side= 80 psi
Also took a picture of both cylinders and piston crown. Both crown look ok, some marks on pto cylinder. Maybe piston ring broken?
