SeaDoo Speedster 2004 2-strokes DI. limits to 5K RPM
fortuneplaza
I have a weird problem.
The boat runs great about 10 minutes then it drops RPM to 5K.
I was trying to find any pattern in its behavior and found out that when I put it in reverse and run about 15 seconds the problem is gone. I can move forward at full speed then engine stalls at 5K rpm again. Each time the same result but the time between stalling and moving reduces up to a couple of minutes. Then I got a long beep..
I had problem with the boat last year. It ran at idle speed only and the problem was faulty TPS sensor. One of them. I think that I made bad decision changing just one sensor and not both of them.
It might be the problem. I am waiting for mechanic with computer diagnostic tomorrow. Let you know if he will find something. At meantime I am curious if somebody had the same issue?
