chrisjet83
Hey fellas, I have a quick question. So I have a few old 96-98 Seadoos ( 96hx, 95xp, 98xp limited and 96spx) and was doing the carbs on the HX over the weekend. The back carb had some issues and was bad from salt water (the carb without a fuel pump ), so I replaced it with another 720 carb I had lying around. The thing was, it was another front carb, I just switched all the inside fuel pump parts, jets, and springs off to the other one, so it was basically the same. The only difference was that one of the fuel lines was facing the other way, so I connected it with a new, longer hose. I wanted to see if that would still work before I put them back on, or should I get another rear carb?
Chris
Chris
