Seadoosam
Just picked up a 787 GTX. These are the symptoms it is having:
Very very slow cranking. Starter struggles to get past the compression point very often. It will unreliably kick over and crank normally with a just charged, perfect agm battery, but that is it.
Already checked all the electrical connections themselves to the starter, coil, etc and changed out the 2 positives and one negative. Also put power directly to the starter and it hesitated and then cranked a bit slow.
When it does decide to start it is revving very hi at 4k rpms. it is very hard to turn the engine by hand at a certain point. Compression gauge says 140 PSI. It also starts extremely fast like within the first half a crank when it does start and it usually backfires.
I think the timing is just a little off. Do you agree?
Which timing problem should I look at? Is it the rotary valve I need to check or the stator? I’m not sure. Any other input appreciated! I tried to be as detailed as possible! It is my belief this engine was just rebuilt due to the compression and the ski having very high hours. Im guessing the PO couldn’t figure it out after rebuilding it and dumped it
