seadoo gsx ltd help..
deany
hi im new here looking for some help.
i have a gsx ltd 1998 witch i have had 7 years it has been stood last 4, i have just put a new battery on it today to try and start it but it wont turn over from start and stop switch, but will if u bridge the starter it will turn over, when u put the landyard on u get the 2 beeps and after 30 seconds u get a constant load beep.
any help will be highly appreciated.
thanks mark.:cheers:
If the battery LOAD tests good, you may have metal particle interferance in the
stator coils from broken starter bendix bits. Fuse holders, wire connectors, ground
lugs often corrode when sitting idle, as the di-electric grease may have dissipated
or may never been applied. *plug wires too, so remove cap, cut 1/4" off and replace the cap and tie-wrap to secure. Bills86e
ive checked plug caps all ok bendix on starter ok and all earth conections seem to be good. what causes the constant beep?
thanks mark
just realised the beep is low fuel cause gauge not working.
still carnt figuer y it wont turn over of start switch >?
witch relay and where is the stop start solinoid?
thanks mark
also would the relay or stop start solinoid stop it from sparking?
