HobbyJunkie
Hello, I have a 2000 Seadoo GTX 951 Carb and I just rebuilt the bottom end. Now I just put the engine back in place in the ski and it’s compression is around 130 on both sides on cold. Now my problem is that for some reason my carbs are not getting fuel to them. I don’t know too much about these 951 mikuni carbs but are the pulse lines on the carbs supposed to be sucking in air into the carbs or pushing air out through the carbs? Maybe I have the lines connected wrong and a diagram might help. I have looked at a Seadoo manual 951 carb diagram but it’s too confusing and I’m not sure if I have it on right. Also I had recently took the jet-ski out to the lake and managed to get it started now when I had put the ski in the lake I would only be able to hit throttle to about 1/4 of it any more and the ski would shut off. When I was riding it I had the choke pulled very little and the ski would then be able to go full throttle. I ordered carb rebuild kits because I believe that the main needle may not be opening because this ski was sitting for about 3 years with the gray lines before I purchased it (will be switching them soon). But if anyone can help me with where the lines go connected or different diagram on these carbs and if these pulse lines are supposed to be pushing air or sucking in air I would really appreciate it.
