TheStone
Hello all, I just finished a complete rebuild on my 2000 seadoo xp. The engine blew a rod bearing, and beat up the pto piston pretty bad. I went with a new wsm crank, and 1mm overbore wsm pistons. Clearanced the rave valves, and resealed the whole engine. Also replaced all the grey fuel lines. I have the ski back together, and verified that it cranks over, has spark, and really good compression, but have not tried to start it yet. My questions are, will the ignition timing need to be checked since there is a new crank? And will the carbs need to be adjusted since it it is overbored? The ski always ran well prior to blowing up, so I'm not suspecting the carbs were at fault, just a 20 year old ski that's lived a hard life. Thank you for your input.
