Still working on troubleshooting and fixing my 2000 GTI. I rebuilt the carb but I'm not sure if I need to replace the fuel pump check valves.
I can't find any conclusive answer on the fuel pump. In the shop manual it states to blow in the inlet and the valves should allow air to move through. Also states sucking/vacuum should lock and hold.
Both ways for me allow air in/out. I've read that there is no 100% seal.
What is normal? Should any air be able to be vacuumed through the inlet. Same holds true for the outlet. I am able to blow air into it freely.
Thanks in advance.
Thanks in advance.
