Seadoo 3D wont turn over
Fullthrottle8
I am having problems with my '05 Seadoo 3D. The battery is charged and the unit will not even turn over. Any suggestions on what it might be. I put the key in and it beeps, but when I press the start up button nothing happens. Does anyone know what the problem could be?
Thanks in advance!!
When you say nothing happens, do you hear any sound at all? Hear the starter click, or literally as you said...Nothing?
Try taking the plugs out and turning it over. It's possible you are seized.
Get out your multimeter and test the battery, check your connections and cables (battery, starter, etc.) look for bad connections/corrosion.
If nothing at all happens I would take the plugs out and check the starter solenoid...check and see if its clicking...if that clicks...and you can turn the motor over by hand..then I would take the starter out and bench test it....also check the starter button to make sure that is working.
