Seadoo 3d Di 2007 How does the top end get lubrication?
Tikkar
Quick question! How does the top end get lubrication from the oiltank?
All hoses i can see going from the fueltank is quite far down on the engine.
I imagined that there would be a line going to the fuelrail on the fuel injection or something?
One is a vent line in the other one is a vent that goes to the bottom of the compressor
Great! Thanks!
How does the top end get lubrication? All lines from the oilpump if quite far down on the engine. Just curious as i thought it would be a line going to the fuelrail on the injection.
It's a 2-stroke, so on the DI the air and oil (as opposed to air/oil/fuel on a normal 2-stroke) go into the bottom of the crankcase with the crankshaft first creating a mist of oil and air then as the piston travels down it displaces the oil/air mix that now travels through the exposed transfer ports and up into the combustion chamber to be mixed and burned with the direct injected fuel.
