Seadoo 2000 Bambardier GTX Starting issue
jcrond01
We have had issues in the past where we had to adjust the key a few times to get the ski started. I was able to get the Seadoo to turn over once or twice today (just took it out of storage). Then I recharged the battery but the sea doo will no longer even click. I used the connections and the battery on another PWC successfully.
Not sure if it makes a difference BUT when I reconnected the charged battery, I had the connections backwards.
Just so you know this is the 4 stroke forum, you want the 2, but connecting the battery backwards can sometimes blow fuses, I've seen it happen in cars.
That was exactly the issue. The 5amp fuse blew. I found it after the fact on on threat in the forum but thanks for the response.
