Hi everyone,
last year I bought a 2003 Sea-Doo RX and completely rebuilt the engine over the winter.
During the break-in I was very careful:
When I looked for the cause, I discovered the following:
My questions are:
Thanks in advance!
- for the first ~3 hours only up to 30% throttle, always varying,
- then another ~4 hours with a maximum of 75% RPM, also with strong variations.
- The 3 bolts that fasten the two-part exhaust manifold (aluminum cast) to the cylinder had broken off.
- One stud with nut was still intact.
- Both side vibration dampers on the large manifold body as well as the damper on the second manifold (below the fuel injection pump) had vibrated loose.
- All bolts were installed with Loctite.
My questions are:
- Why could this have happened?
- Did I do something wrong during reassembly?
- Why are there such strong vibrations, even though the engine itself runs well and shows no obvious issues?
Thanks in advance!
